2011 mazda 2 neo cooling fans not coming on after repair - Mazda 2 Forum : Mazda 2 Revolution Forums
Thread Tools
post #1 of 3 Old 08-25-2020, 08:38 PM Thread Starter
egr88
Junior Member
Quoted: 0 Post(s)
Hey guys
my wifes mazda 2 neo had a new radiator put in after the front end was damaged now the cooling fans arent coming on trying to figure out whats wrong, no codes via obd2
the ac system was regassed and is working although it is noisy which makes me think they didnt do something right.
also there is a 2 pin plug down near the radiator fan plug which is not connected to anything,
I thought this might be for the 2nd NTC sensor in the radiator but the radiator they put in doesnt have one
I am pretty frustrated to say the least
thanks for any ideas, fuses are fine and I swapped the fan relay no change
egr88 is offline
Sponsored Links
Advertisement
post #2 of 3 Old 08-26-2020, 02:43 AM Thread Starter
egr88
Junior Member
Quoted: 0 Post(s)
wel I tested the fan plug with the engine running and Im getting 12v on both pins + pins and good ground on both negative pins - the voltage/relay clicks on and off with the airconditioning compressor, so it looks like the fan they swapped in is bad..
my concern is that without the AC on the engine seemed to be at temperature but the system was not triggering the relay I was not seeing votlage at those pins after watching for quite some time for the 12v .. I dont know why .
I measured the NTC sensor on the cylinder head and it was within range cold and hot
egr88 is offline
post #3 of 3 Old 09-03-2020, 06:32 AM Thread Starter
egr88
Junior Member
Quoted: 0 Post(s)
ah cool anyway
the shop swapped in another fan because I tested the pins and thats fixed it
fans now come on with AC
I realised the cooling fan itself doesnt come on until 100 degrees celsius at low speed and then at 108 celsius it will come on at high speed. it comes on at low speed (1 pin +) iwth low refrigerant pressure and at high speed (2 pins +) at medium refrigerant pressure - it was all in the service manual just took me a while to find the specs
egr88 is offline
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Mazda 2 Forum : Mazda 2 Revolution Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
OR
Log-in
User Tag List
Thread Tools
Show Printable Version Show Printable Version
Email this Page Email this Page
Forum Jump
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
For the best viewing experience please update your browser to Google Chrome
