Mazda 2 Head Unit DIY Install - Mazda 2 Forum : Mazda 2 Revolution Forums
Reply
Thread Tools
post #1 of 19 Old 07-03-2011, 11:19 PM Thread Starter
CommanderBob
Member
Quoted: 0 Post(s)
Warning: These panels scratch ridiculously easily. Do not use prying tools to remove any panels. With the right pressure in the right places, every panel can be removed with just your fingers.
Disclaimer: I am an amateur. These are not professional directions, nor do I claim to be a professional. Proceed at your own risk. While I doubt you will break a panel almost regardless of how hard you pull, I am not responsible for any damage you incur while attempting a radio install on your own.
Rules:
1) No prying with tools until you've tried to dislodge the panel for at least 5 minutes, and only then with the understanding that you will most likely dent or otherwise damage the edge of the panel.
2) Take your time. Have all day to get your work done so that you have all the time in the world to figure out how a panel comes off.
3) Do not under any circumstances set a panel on top of another panel, or on any hard or abrasive surface. No garage floors, no metal surfaces, nothing. I cannot stress enough how easy it is to mar this plastic.
Tools:
Very small flat head screwdriver
Regular Phillips head screwdriver
10mm socket with about 10" of extension
For the replacement faceplate, I also needed some diagonal snips and a sanding block and ~100grit sandpaper. A Dremel with a cutting wheel and sanding drum would also suffice.
Parts:
Metra Wiring Harness 70-7903
Metra Dash Kit 99-7518B
Metra Antenna Adapter 40-HD10
I opted to complete the indoor work first, then do the install. Indoors you will need to prep your faceplate and install your radio into it, and do your wiring harness. I didn't take pictures of the faceplate process. I installed a 2din radio. I had to trim out the center bar with snips, sand the excess bumps even with the edges, snap in the side panels, screw on my radio, and put on the white clips. It will be different for you if you do a single din radio. The rest that I will be detailing is universal.
Install:
1) First up is wiring the 70-7903 harness to your radio's harness. With the one from my Pioneer, it was as simple as matching up the colors on both ends. If you look closely at your metra harness, you will note that the wires are labeled. It is worthwhile to check the manual for your radio to be sure that the colors and functions match.
I am terrible at soldering. You could use
with a crimper, but I need the practice.
I didn't have any heatshrink tubing handy, so electrical tape sufficed. I wrapped the bunch on either side of the soldering afterward to help keep things tight.
2) Now for the dash pieces. A ton of pieces have to come out to remove the radio from your vehicle. The one piece that looks like it needs to be removed but doesn't (I learned the hard way) is the seatbelt/hazard light panel. Leave it in. It can be popped off after you remove the entire bezel.
Get in on the passenger side with the seat all the way back, and start with the Shift Knob simply unscrewing it like a bottle cap. Those of you with an automatic, I'm sorry. The manual just drives better
3) Now the surrounding frame. Get the edges of your fingers under the edges of the panel and pull straight up. Or just get some friction on either side, but it pulls straight up and off.
Note the clips are all straight down
4) The glove box, a hand on either side and pull straight toward the back of the car.
Just little U shaped clips
Which clip to the rod
5) Now to the little panels in the foot wells. Use your small flat head screwdriver to pop the tab on the little push pin clips in both footwells. Once you've popped the middle, just grab ahold of the it with your fingers and pull it straight out. If it doesn't pop out easily, push or pull on the panel toward the front or back or the car to try and take pressure off of it.
The little panels in the foot wells were hard to photograph. Stick your fingers into the top edge joint and work them toward the back of the car along the crevice. There are clips that need to pop out straight toward the car doors on both the driver and passenger panel, on the edge closest to the seat. The passenger one has a single bent piece that hooks in but does not clip.The driver one just has a straight piece that hooks in at the front of the foot well. Pull both panels straight toward the back of the car once you've popped the edge clips outward.
Passenger
hook closeup on left
Driver
Limited to 25 Images. (ugh) Breaking post in half for more....
CommanderBob is offline
Sponsored Links
Advertisement
post #2 of 19 Old 07-03-2011, 11:25 PM Thread Starter
CommanderBob
Member
Quoted: 0 Post(s)
6) On the newly revealed edge, remove the screw on both sides with your Phillips head screwdriver.
7) Remove the center console panel which is located beneath the shifter. There are two clips on both sides that need to be pulled straight toward the back of the car. Once they give way, put your hand over the clips in the back on both sides and roll the panel backwards. Your hand protects the dash, and a cloth over the power ports to keep it from scratching the panel your removing is very highly recommended.
8) Now the panel just below the airbag on the passenger side. all clips pull straight toward the back of the car. I would start by getting one hand under the edge of the panel at the glovebox hole and the other against and into the grove in the doorjamb and work that corner out. Once it is loose you can slip your hand across the top and work the upper clips out, and then down the middle of the car. There are two pegs to be careful you do not break, they help keep the panel lined up. Last should be the bottom right corner, which needs to slip out from behind the lower framing piece. It may be necessary to pull off a little of the gasket and pull outward on that panel to get the other one free.
bottom right corner
Clips on the back
9) The driverside panel, to the left of the radio right by the ignition. Just tuck your fingers in behind that panel by the ignition and pull it straight toward the back of the car. You only need the upper edge to be out and shifted down a little. I did not remove the whole panel. Don't have your keys in like my pic shows
10) THE HIDDEN GEM
I am using this pic from http://www.mazdas247.com/forum/showt...T-in-my-Mazda2 posted by Kags1969 in his how to thread. I did not get a good pic of this one. With a 10mm socket and a good bit of extensions, remove the bolt in the picture. This is absolutely necessary, it bolts into the side of the radio as some kind of theft deterrent (on a stock radio no less.) Take your time, don't drop it into the dash.
10) Remove the two screws in the front at the bottom of the faceplate, though I'm sure you were itching to do that earlier as soon as you saw them. (note, my pictures show the driverside panel still attached. it should be hanging loosely at this point.)
11)
Put one hand on either side of the radio toward the bottom and work it out. There are about 3 clips on each side and a bunch along the top. Once you feel the first set of clips pull out, work your fingers higher up pull on the next set. Don't just pull from the bottom, you might break the clips for the hazard button panel.
12) Unplug the wires in the back using your handy small flat head screwdriver for any pushtabs that you can't get. Remove the hazard button panel by pulling it forward off of the faceplate. It has a hidden metal clip on both sides. Reattach it to your new faceplate, plug in your wires, plug in your new head unit and pop the faceplate in, and reverse process!
I was installing an indash GPS, so I ended up wiring my GPS receiver over near the passenger door and up behind the gasket. I tried it just directly on top of the head-unit completely out of sight but did not get reliable service.
I also had a mic, which I put into a ring of cardboard and taped it in where that funny vent-looking thing is by the ignition. Worked perfectly for me.
Compared to the other installs I've done, this one rates reasonably high on the difficulty level. All of those panels have to come off to get to the radio, because the stock faceplate has tabs in behind the side panels. The replacement one didn't have those tabs, so you may be able to get away with only taking off the lower panels. The bolt was totally random and unexpected. The panels scratch way too easy, and since I did it with little instructions I tried to remove the hazard button panel thinking there were screws behind it and ended up breaking a post on it, chipping up the OEM radio plate, and even putting a little divot in the upper edge of the dash. dang. Now I've hopefully given you over-the-top instructions so that you do not make my mistakes!
If this helps you, please do register and give me a shout out I'll be glad to try and answer any questions.
post #3 of 19 Old 08-12-2011, 03:34 PM
kidmotor
Junior Member
Quoted: 0 Post(s)
steering wheel issues
I'm having problems with my steering wheel controls, I should be able to wire everything right up with just a steering wheel interface adapter, but I am wondering what I need to do to get my info button to work again.
kidmotor is offline
Sponsored Links
Advertisement
post #4 of 19 Old 08-12-2011, 03:35 PM
kidmotor
Junior Member
Quoted: 0 Post(s)
I'm having problems with my steering wheel controls, I should be able to wire everything right up with just a steering wheel interface adapter, but I am wondering what I need to do to get my info button to work again. does anyone have any ideas?
kidmotor is offline
post #5 of 19 Old 09-14-2011, 07:31 PM
DjSayWat
Junior Member
Quoted: 0 Post(s)
Thanks for the excellent info
Thanks Bob for the detailed instructions.
I studied your steps alot before I attempted mine.
My previous car was a 07 WRX which could be the easiest stereo change.
DjSayWat is offline
post #6 of 19 Old 09-16-2011, 08:29 PM Thread Starter
CommanderBob
Member
Quoted: 0 Post(s)
Glad to hear everything worked out for you!
I put a radio in my sister's 09 Forester and it was dead simple. If you were good, you could just pull off the center frame. If you were careful, you took off one screw and slid along a panel from the passenger side for access to the back edge.
There are way more steps than most cars require to get to the head unit in the m2, but the results turn out pretty good!
post #7 of 19 Old 09-20-2011, 03:33 PM
ZoomZoom
Senior Member
Quoted: 0 Post(s)
I was about to say, nice toe nails, until I noticed your wife was helping you haha
very clean install! I like how it looks. How are you liking the headunit you're using? what make/model is it? looks like a Pioneer or Clarion
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
ZoomZoom is offline
post #8 of 19 Old 11-04-2011, 10:35 AM
wcuhatter89
Junior Member
Quoted: 0 Post(s)
I guess I (his wife) should answer this because I'm the one using it! Let me see.. it's a Pioneer.. uh.. 700 something.
I do like it.. but I feel like its always had some quirks. It takes a while to start up and then sometimes takes a couple of pokes to sense my finger. The navigation system is a little funny, you can't zoom out or anything.
OK I changed my mind maybe the hubby should answer.
wcuhatter89 is offline
post #9 of 19 Old 05-17-2012, 09:22 AM
yualfred
Junior Member
Quoted: 0 Post(s)
Thank you so much Bob for the detailed info and pics. Just got my new M2, and looking forward to replace the head unit myself. At least I know what Im gonna deal with. This is the unit I am looking at to replace with:
http://www.aliexpress.com/product-gs...olesalers.html
yualfred is offline
post #10 of 19 Old 05-26-2012, 07:56 PM Thread Starter
CommanderBob
Member
Quoted: 0 Post(s)
Glad to help, let me know if you have any issues!
The one you are looking at will be a nice factory-look replacement, but may be of suspect quality. Look into anything you can find review wise. I've heard good and bad over on the corolla forums about the different Chinese off-brand headunits. Good luck!
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Mazda 2 Forum : Mazda 2 Revolution Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
OR
Log-in
User Tag List
Thread Tools
Show Printable Version Show Printable Version
Email this Page Email this Page
Forum Jump
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
For the best viewing experience please update your browser to Google Chrome
