So I was driving down the road the other morning and it was humid out and my front windows started to fog up so I did what Ive usually done with other cars when this happens which is to turn on defrost and that usually clears up the windows but that didnt work. I actually had to turn on the ac then they started to clear. Is this normal?
Yes, the majority of vehicles kick on the compressor when you set the control on defrost. A few including the Mazda 2 require you to press the AC button. I have an old Miata that works the same way.
On a side note, I had a Datsun back in the 70's that worked the same way but it had a nice feature. The AC had a prestart setting. This would remove the heat from the AC vents without blowing any air. After a few seconds, just turn on the AC and it would blow cold air without the nasty heat at 100+ degrees.
Don't forget to set the air intake slider to Outside air, too. The A/C system doesn't just cool the air, it removes water vapor, too. This makes it ideal for defogging, and it works even if the Temperature Control is set for heat.
