Greetings, New member here. I have A 2012 and I want to install a set of OEM Dumo projectors. What does it take to make that happen?
Thanks in advance.
Thanks in advance.
Hello again, Update 👍
Using the original wiring harness from a Dumio, you need to tap into the black wire feeding the bright bulb, to supply power to the low beam ballast. Then ground the other side of the ballast , to a secure place. When you turn the lights on, you are making the black wire live and the low beam will stay on until you turn the lights off. 👍👍👍
I changed out the 9005 for a led 6000k White 👍
A forum community dedicated to Mazda 2 owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
