1 - 9 of 9 Posts
Hey guys,
My name is Nick.
I need some advice on my Mazda 2 Engine Swap...
Is it better to do an engine swap with the Mazda Speed 3 Turbo engine?
I love speed and power but I just want to know is it going to be a hard swap or easy drop in swap with minor troubles getting it bolted in?
Please I need help... I'm having a hard time finding information for this swap build.
:D:D:D>:)
It is possible, Mazda built a concept 2 in 2011 that had the 2.3 MZR from the Speed3 (albeit with DI, but size shouldn't be significantly affected by that). However, that's not a common swap, to my knowledge it's never been done outside of that concept. Therefore, it will be very expensive, since all the mounting hardware, exhaust and probably intake will have to be custom made. You'll also need to find space for an intercooler (probably need a higher hood with a scoop to accommodate that), and a larger radiator in addition to the engine. The stock transmission and differential won't hold up to the extra torque, so you'll have to stuff an MS3 (or other, more robust aftermarket) clutch/transmission/diff combo in. To handle the additional power and weight, you'll want wider, gripper tires, and probably some stiffer springs and dampers. If you're doing anything more than highway pulls and tooling around town you'll want some good brakes, probably something bigger than stock.
If I walked into a shop and asked for it to be done, I'd be expecting it to cost 20k AT LEAST (25-30k with the suspension, tires and brakes). And it wouldn't be reliable, either. Swapped engines don't go through the thousands of hours of testing that the originals do, and little things like wires or hoses rubbing through and other annoying little problems happen all the time. Don't get me wrong, I think it would be an awesome swap, but you'd have to be very dedicated, willing to dump money, and it probably shouldn't be your only car for it to not become a major PITA. If you meet those requirements and decide to go through with it, please post a build thread.
2005 Mazda 2 DY 1.5L ZY-VE (Maxx)
am currently doing a kswap
whats the current reliability of the swap? Id rather stick with a low power engine, say 130-150HP otherwise i feel like its more of a hassle rather then an upgrade. Id feel depressed not being able to rev it out. Most roads here are 60-80km/h so you only get to the end of 2nd gear. Only reason 3rd and 4th gear are there is for economy, only time i use 4th is when going upwards of 120km/h (75Mph)
Plus our roads aren't designed for high speeds. So you would be wasting all that engine power...
Any suggestions?
Can a 1.5 L ZY-VE be swapped into the 1.3 L. Because the motors cost the same in case the 1.3L engine does break 1 day and more power is needed?
Should be able to, it was made to be in all of the Mazda 2's upto 2011. you will need the ECU which comes as part of the engine cover/ intake manifold.
as for compatibility, i have no idea, the 1.5L is a multiport injection so it has Direct injection and port injection, it also has vacuum controlled variable length intake runners depending on the version not to mention it also runs glow plugs ( for some reason?). overall it is better but you might find that getting a clutch for it will be a pain as most of the clutches i have replaced feel way off.
most of the stuff you can find online, just look up mazda 2 and look for the engine that has the ECU and intake in one. one issue i have found in the knock sensor dies at 140,000km mine gave out not too long ago, i also found that spark plug gaps are jank, i want to do a test on them at some point with 0.99mm as for the 1.25-1.6L excluding 1.5L all seem to use 1.0-1.3mm but they lack responsiveness. i have found that if you tighten the gap without changing the distance it gives it way more pep but if done incorrectly will sheer off the coating causing missfires. Went through a set of plat plugs in less then 7000km. depending on if your running low resistance tyres or not you will average 270-500km per tank, 270km for constant high rev and full throttle, 500km for easy low RPM low throttle.
if you would like more info id be happy to provide it. unfortunatley my hubs sheered off and im still waiting on them to get my car fixed so ain't no drivin' for me.
also if its running properly and depenidng on the version, you will have a 0-100km in about 6.8-7 seconds. shifting adds 2 seconds so if it were sequential gearing 4-6 seconds ez
1 - 9 of 9 Posts
