1 - 4 of 4 Posts
My 2011 Mazda2 has been having intermittent radio issues. The radio will cut out and then it will work sometimes. If I hit the dashboard as seen here it will work again for maybe a few days and then it will stop. Any help? I also can't figure out how to take the dashboard apart to check for loose wires. Thanks.
Had the same issue with my '11, then it died completely. Talked to Mazda, some internal fuse in the head unit, well past warranty to replace. If you want to stay with a stock radio, then try ebay, or aftermarket.
After I take mine out I am going to take it apart and see if I can find the issue and post a repair.
This is an old thread, but did you ever track down the cause in the audio unit?
1 - 4 of 4 Posts
