Hey everyone , keep getting this code come up p0850 , could the switch be bad ?? Also idling high code comes on together with this.
Any one know where I can find this switch in the car ?? Car is standard.
Thanks
Dan
Indeed yes, most of the time it is the switch which is faulty. I would generally do a reset test by disconnecting the battery for a while and then see it the code comes up later. If it still does, then it is switch replacement time. If not, you are good to go. Just reset your codes first and then act accordingly.
used auto parts
