361 - 380 of 447 Posts
Buenas tardes agradeceré si me puede compartir la versión de firmware para Latinoamérica
Hello ALL!
New firmware is out now for 4A N or ADR in 74.00.324A
This is the FIRMWARE ONLY that is the Operating System for your Mazda Connect or MZD Connect which uses the .up Firmware ONLY.
IF you are after any copies YOU MUST Message me privately for the link to Download the file, ALL install instructions etc are included in link.
I supply ONLY the Genuine Mazda Files, I do not hack, I do not recommend ANY Tweaks as they are more hassle than what they are worth.
ONLY the GENUINE Files I supply, exact same as your Mazda Dealer would use, nothing else.
This means ALL regions worldwide which use the .up Firmware use 74.00.324A as the latest and most updated Firmware.
74.00.324A NA N for North America, USA, Canada, Mexico, etc.
74.00.324A EU N for Europe and UK, etc.
74.00.324A 4A N (ADR) for Australia, NZ, Middle East, Thailand, South Africa, Oceania, etc.
Me gustarĂ­a que me compartieran el link de descarga de esta versiĂłn, gracias.
Thank you for this detailed info. Would love to update from v70 to the latest version since I have issues with connecting. Turning the car off and on usually resolves this. Hopefully updating to the latest version will resolve this.
hello my brother
I am from Indonesia.
I have a 2014 Mazda 2 Skyactive.
I would like to ask for your help regarding my MZD Connect which always turns itself off after a while the car is turned on
for my firmware version it is still at 42.00.400,
can this still be fixed?
ALERT: Please be aware that MAZDA ONLY Supports the WIRED Connected AUX Hub and Two Large USB Cables for Carplay and or AndroidAuto Conversions.
GENUINE Mazda CP/AA Wireless is ONLY obtained by using an updated for ''Wireless CMU'' (the inside Dash Hardware) and the updated new AUX Hub.
MAZDA DOES NOT SELL or SUPPORT CP/AA WIRELESS VIA a ''Carplay Dongle'' only via more expensive "Wireless CMU".
These ''Carplay Dongles'' are not from Mazda nor can be considered a Genuine Mazda Part.
They are sold via Amazon, eBay etc, I would be careful about their longevity (or life span).
Personally I Only recommend the ORIGINAL CP/AA Update which requires the 2 Wired USB Cables and Updated AUX Hub or Box installation AFTER your 74.00.324A Firmware is working. The Latest and final 74.00.324A Mazda Firmware
does work fine with these wireless Carplay Dongles, HOWEVER I recommend you ONLY use the Instruction I supply with all my Genuine Mazda Firmware as these other paperwork suppled is either old and outdated Firmware from a Google Link and instructions which is very vague.
NOTE: THERE ARE SOME PEOPLE CHARGING YOU FOR THESE UPDATES IN RUSSIA or UKRAINE, or on eBay or Amazon, I NEVER CHARGE YOU, YOU DO NOT PAY FOR NEW FILES, EVER
ALSO NOTE: YOU CAN NOT CHANGE or SWAP INFOTAINMENT SYSTEMS.
ALL EXPORT Mazda 2 USE the 6th GENERATION MAZDA CONNECT.
7th Gen MAZDA HOME SCREEN has the White Text on Black Screen.
6th Gen MAZDA HOME SCREEN has the Red Select Icons on Black Screen.
PLEASE NOTE: 74.00.324A IS NOW THE FINAL FIRMWARE as all Mazda Cars using this .up Firmware is OUT OF PRODUCTION and No Longer Installed in any New Mazda's made in 2024.
Yes, this Firmware update is for all Mazda 2s with the following Touchscreen as shown above then Yes you can also have the working and 100 % Genuine Mazda Carplay and or Android Auto if you desire.
The Genuine Mazda Firmware part of this I supply to you is all free you just message me (see below) the Country and Region you need with your current in car current Version number in use today, I will return you with the correct download link.
To find out what Version is in your Mazda 2 now do the following..
1. Touch Red Round Cog of "SETTINGS" on homescreen.
2. Next top of the screen far right grey Folder of "System".
3. Scroll down screen to "About", touch About.
4. Then touch "Version Information" this will show you current Firmware in use in your car today and the country or region code like EU N, or NA N or 4A N so please also must tell me what this is listed in your return message to me.
Once you have installed latest firmware and used in car, you then must Buy and Install the two sets of Genuine Mazda Parts which is the all new Aux Hub box and all new Cable Set of two cables that fits between existing CMU in dash (behind touchscreen) and new Aux Hub (where SD Card slots in).
New CP/AA Kit in Pic below.
You do not have to install new parts if you do not want a working CP/AA. You can just ONLY update to the new and latest Firmware 74.00.324, which gives you the latest updates and a faster to load and use MZD Mazda Connect System.
Please Note: I DO NOT supply or help with any AIO TWEAKS at all, you will need to start a new thread , please do not ask me about AIO Tweaks here, I will not reply.
WARNING âš  : DO NOT USE ANY USB FLASH DRIVE LARGER THAN 16GB IN SIZE.
ALSO NOTE: Do not rely on your Mazda Dealer to update your Firmware for Connect as most never will unless you complain of a specific issue or fault.
NOTE: Links to secure new Genuine Connect Firmware WILL NOT ever be posted publicly IN THIS THREAD or Forum, they will ONLY be supplied via a Private Message to you direct.
IF you are after the Genuine Mazda Firmware as listed PRIVATE MESSAGE me ONLY Here in this Forum with your Model, What OS Version Numbers are in each (Fail-safe and Reinstall) and what Country is car used in, SEND ME a Picture ONLY of the Screen "OS VERSION" Settings. New Members must post in Forum to Qualify.
CLiCK HERE Below...
Click to Message
PLEASE DO NOT ASK for FIRMWARE FILES in MULTIPLE MAZDA FORUMS.?
IF YOU ARE Messaging "ASH8" which is ME, then I Am THE SAME PERSON !
You wont get what you want any faster, but create more work for me
WARNING: PLEASE NOTE, IF YOU CAN NOT SUPPLY ME A PICTURE
OF CARS EXISTING FIRMWARE VERSION IN Your PRIVATE MESSAGE TO ME TO VERIFY I CAN NOT ISSUE YOU THE MAZDA CONNECT UPDATE FILE(S).
ALL THE .Pdf File INSTALLATION INSTRUCTIONS ARE SUPPLIED WITH EACH FILE SET.
NOTE: MY REPLY to YOU can take up to 14 Hours as I am in Australia, be patient. Do Not download Firmware Files from any other websites as they offer zero support and usually only one of the three Regions.
Hi Ash8 i can't seem to DM you directly, first of all thank you for making it easier for us consumers and providing alternative options (DIY option) than go straight to other shop ripping us off. I'm looking for 74.00.324A 4A N (ADR) file. Would you be so kind to send me a copy or DM me so i can provide a snapshot of my version OS or provide me a link where i can access it. thank you in advance and Happy Holidays.
Tips, Firmware Install instructions in.Pdf are also included with your particular download link.
Even a short how to install firmware video can be supplied if you wish.
CHANGELOG for NA N Firmware, EU N and 4A N will be similar fixes.
APPLICABLE MODEL(S)/VINS
2014-2018 Mazda3
2016-2023 Mazda2
2016-2021 Mazda6
2016-2023 CX-3
2016-2023 CX-5
2016-2023 CX-9
2016-2023 MX-5
DESCRIPTION: Latest to Original Version of Firmware for all GENERATION-6 Mazda MZD-CONNECT.
Some vehicles may experience the symptoms mentioned below, which can be fixed with the latest software update:
• Updating MAZDA CONNECT to the latest version will erase/remove any customization created by unauthorized software like AIO.
• Unauthorized customization software like AIO will not work on the latest version of MAZDA CONNECT software.
• The latest version of MAZDA CONNECT software cannot be rolled back to an earlier version.
• Mazda does not recommend unauthorized customization of MAZDA CONNECT due to the possibility of unexpected problems. Any issues related to this will not be covered under Mazda warranty policy.
The system performance has been improved as follows:
Ver. 74.00.324A fixes ALL these software errors (bugs) below from Version 55.00.650 to 74.00.324A:
• If the shift lever is operated quickly while displaying the CarPlayTM screen, the rear view screen may not return to the CarPlayTM screen.
• When the gear position is shifted into P from R, the screen may not return to the previous condition before shifting into the R position.
Ver. 74.00.311 fixes these software errors (bugs):
• When using CarPlayTM, sound may not come out from the driver side speaker.
Ver. 74.00.310 and later fixes these software errors (bugs):
• Frequent temperature warnings may appear in the center display.
• The time in the center display may be inaccurate.
Ver. 74.00.230 and later fixes these software errors (bugs):
• [Mazda6 (US 2019-2021)], [CX-5 (US 2019-2021)], [CX-9 (US 2019-2021)] SiriusXM radio does not work properly.
(SiriusXM cannot be selected, only certain channels appear in the list, the sound turns off and/or the center display shows an error message such as “Check SiriusXM Tuner” or “Unable to Connect to SiriusXM Radio”.)
From V70.00.367 and later fixes these software errors (bugs):
• [Except English] The translation of the message for the back camera is not correct.
• The Maintenance notification function (except when using Flexible setting) may stop counting after replacing the instrument cluster. It resumes counting after a factory reset operation.
• The speed limit for the other direction may appear in the navigation screen. To correct, the map version must be 18Q4 or later in addition to a CMU update.
• A phone number (including pause symbols) registered as a favorite may not be dialed and the “Loading” message continues.
• The "Display Off" function does not work if activated while a road name etc. is displayed at the top of the screen.
• The information (artist, title, album etc.) for a track on a USB audio device may not appear.
• [Ver. 70.00.110 or later] Certain USB audio devices (SONY NW-A45 and NW-A35 etc.) may not be recognized.
• Certain Android smartphones (HUAWEI P20, P30 Pro and Mate 20 Pro etc.) may not work as a USB audio device.
• Country information (such as alcohol limit etc.) in the navigation screen may not be correct.
To correct, the country information has been removed in the latest version.
• The information (artist, title, album etc.) for an ogg format file in a USB audio device does not appear correctly.
• The play list may not work for a USB audio device with Android 9 or later OS.
• SiriusXM radio does not work properly.
SiriusXM cannot be selected; only certain channels appear in the list; the sound turns off and/or the center display shows an error message such as “Check SiriusXM Tuner” or “Unable to Connect to SiriusXM Radio”.
• The play list may not work for certain USB audio devices (HUAWEI P20 Pro with Android OS 8.1 etc.) when used as a USB audio device.
• The CMU may reboot when playing a CD/DVD.
• The CMU may reboot while driving.
• Changes for sound setting (Bass, Treble, Fade, Balance) may not be kept after going into sleep mode.
• Cars With Traffic Sign Recognition System (TSR) While in ACC-ON mode, improper setting items (Speeding, Speed Limit) appear in the navigation setting.
• While playing tracks from a USB memory, artist and album names may appear as “unknown”.
• While playing tracks from a USB memory, certain mp3 file will not start showing “Loading” message.
• Some of the favorite destinations appear duplicated and may not allow editing or deleting.
• Right after starting the engine when trying to see the 360° view monitor screen, the black screen may continue for 20 seconds.
• When the transmission is shifted into Reverse, the rear view monitor does not appear.
From V70.00.352 and later fixes these software errors (bugs):
• [Mazda6 (US 2018-2019) (Mexico 2019-2020)] The center display turns to a black screen due to the back light of the display turning off. (Further improved)
• [Mazda6 (US 2018-2020)], [CX5 (US 2019-2020)], [CX9 (US 2019-2020)], MX-5 (US 2019-2020) starting with JM1ND MX-5 (built after Apr. 11, 2019) When listening to SiriusXM radio, the sound turns off and the audio source changes to one of the others by itself, and the center display shows an error message such as “Sirius Channel Unavailable” or “Unable to Connect to SiriusXM Radio”.
From V70.00.335 and later fixes these software errors (bugs):
• In the CMU update package, the latest Gracenote® database has been included.
• The System Update screen menu shows “Update package” instead of “Reinstallation Package”. The "Fail-Safe Package” has been removed as a separated install.
• The brand icon on CarPlay screen has been updated.
• Font and location of texts like i-stop, i-ELOOP and average data on Fuel Economy Monitor screen have been improved.
• When using SiriusXM Travel Link, block letters of direction are greyed out on the Fuel Prices and Parking screens.
• On the Home screen, white stains appear in the status bar.
• [MX-5 RF] When talking on BT hands-free, the person on the other end hears strange voices (like an echo).
• [Mazda6 (US 2018-2019MY) (Mexico 2019-2020MY)] Center display turns to a black screen because the back light of the display turns off.
• In LAS and LDWS setting menu, “Rumble” appears as “Rumbl.”.
• The Display OFF setting is not kept when the ignition is turned off and on before the CMU goes into sleep mode.
• When using SiriusXM Travel Link, the subscription status for each service should appear (subscription Information screen has been added).
• When using SiriusXM Travel Link, the business hours should appear for parking lots (business hours screen has been added).
• If a “subscription suspended” event occurs when listening to Sirius XM, an incorrect dialog screen appears instead of changing the channel to Ch 1.
• When radio is selected for audio source and a hands free call is finished, the radio sounds for a very short period of time even when it is muted.
• After engine start, trhe screen freezes at the loading status.
• If the gear is shifted to reverse to display the rearview monitor while loading data from a USB device (when USB is selected for audio source), the screen changes to the Home screen instead of the USB audio screen when shifting to drive or a forward gear.
• When an artist is selected using voice command for USB audio, the wrong artist’s album may be selected.
• After parking, the current location on the navigation screen may not move until turning the ignition off and on.
• [Android Auto used at the south latitude or the west longitude (CarPlay is not applicable)] When ACC is on or engine is running in a location where the GPS signal is unavailable, a wrong current location (Ex. China) appears on applications such as navigation, weather forecast etc. When the GPS signal becomes available, the correct current location appears.
From V70.00.100A and later fixes these software errors (bugs):
• Even if the vehicle is not equipped with SiriusXM, it appears in the source list.
• When playing audio files on a USB memory device, it may take a long time to start playing.
• When playing certain BT audio devices, “Unknown” is displayed for track, artist and album names.
• During a call, another call will not be displayed on the screen if it comes in within 30 seconds of the start of the current call.
• On certain vehicles equipped with a Multi-Information Display (MID) in the speedometer, inactive customization item ”Sync Average and Trip A” is not grayed out and looks active.
• When using certain mobile devices, the sender name for a SMS message appears differently (i.e., first and last names appear in reverse order) from the contact list (phonebook).
• When playing music with a play list on a USB memory device, the play list does not appear if the play list consists of more than 50 tracks and includes a title longer than 128 characters.
• When pressing the volume knob to mute, an audio source will not pause. With the improved software, CD, USB memory device or BT audio will now pause.
• When returning to the Fuel Economy Monitor, it does not remember the previously displayed page, Control Status or Fuel Consumption.
• When playing audio using an Android device via USB connection, it suddenly skips to another track.
• When playing audio files on a USB memory device, it stops playing and will not go to the next track.
• When playing mp4 audio files in an Android device via USB connection, they are not displayed nor played.
With this improved software, mp4 audio files can be displayed and played, but mp4 video files are still not applicable.
• When playing a play list for mp4 audio files on a USB memory device, they are not displayed nor played.
• Play list shuffle play for a USB memory device will not resume correctly and repeats playing the first track several times.
• In the Fuel Economy Monitor, Average Fuel Economy History shows data in wrong order.
• When receiving another call during a call via BT hands-free, selecting “Hold + Answer” results in a black screen.
The call is still active but the screen will not recover until turning the ignition switch to off.
• After using voice recognition on an iPhone via BT connection, the center display continues showing own phone number and will not return to the previous screen.
• While driving, the screen freezes and reboots or continues rebooting.
• [Canada] If there is a failure to reset the oil maintenance monitor using the trip meter switch on the instrument cluster after the oil maintenance monitor reset operation on the center display, the following can happen.
â—‹ The wrench mark (Oil Change Due message) will not clear using the reset menu.
â—‹ The wrench mark (Oil Change Due message) will be displayed even if it is before the oil change due time.
• Shuffle play for a USB memory device will not play all tracks.
• Album art may not appear correctly.
• A play list on a USB memory device will not show all of the tracks if the data with an invalid file path in it exceeds 100 tracks.
• When playing audio files on a USB memory device, it plays the same track twice with a slight delay in between.
• The home screen is shown and will not move to another screen.
• After updating the CMU, the contact list (phonebook) and the call history for an iPhone will not appear.
• A BT connected iPhone shows the pop up screen prompting download of the “Navibridge” application.
From 59.00.546 discontinued or removed these features/functions:
• Rear view monitor brightness settings have been disabled for compliance requirement.
From 59.00.545 fixes these software errors (bugs):
• [Only vehicles with V59.00.544, except 2017-2018 Mazda3 (Mexico built)] When using Driving Position Memory, a beep sound may not be heard when the driving position adjustment is completed. Display settings for navigation guidance on Active Driving Display may not be kept for the seat position memory.
From 59.00.544 fixes these software errors (bugs):
• When playing a BT audio device, album art is now available when it is found in the Gracenote® database in the CMU.
• Speed limit is displayed on the navigation screen.
• Android 8.0 device is not recognized via USB connection.
• [Only vehicles without Active Driving Display] Traffic Sign Recognition System (TSR) does not keep the alert threshold setting value when performing Factory Reset.
• Wrong caller name is displayed for incoming calls.
• Fuel Economy Monitor may display wrong unit and/or draw bars multiple times instead of once a minute.
• Cell phone screen flickers when connected via USB.
• Traffic Sign Recognition System (TSR) does not alert at the the correct speed limit alert setting. It may alert at +6 mile for +10 mile setting.
• [Version 59.00.540 only] House number not found error pop-up displayed when trying to enter a new address.
From 59.00.540 fixes these software errors (bugs):
• When Pandora® is connecting to the vehicle, the screen color and the logo have been changed.
• Warning Guidance “i-ELOOP Charging” in the center display has been removed.
• i-Pod nano 5th gen will not play.
• [Only vehicles equipped with the Forward Sensing Camera] Warning Guidance message to clear foggy windshiled is shown even if it is not foggy. (The message has been changed.)
• Fuel Economy Monitor may draw bars twice a minute instead of once a minute.
• [Canada and Mexico] Some vehicles in Fixed engine oil maintenance mode may experience that the remaining mileage does not decrease.
• [USA] Some vehicles in Flexible engine oil maintenance mode may experience that the remaining mileage returns to 620 miles (1000 km) from less than 620 miles (1000 km).
• [CX-9 with Active Driving Display] Speed limit display in the MAZDA CONNECT screen has been disabled.
• The setting tab works as if the ignition is in ACC instead of ON.
From 59.00.502 fixes these software errors (bugs):
• USB Auto run vulnerability described in Forbes article.
• System stability and response of the CMU.
  • Minimize unexpected reboots and blank or frozen screens.
  • Faster start up.
  • Faster operational response.
• Connectivity and stability for BT devices.
  • Improved stability of connection.
  • Reduced connection error with internet radio applications.
• Stability for USB audio device.
- Faster response when hundreds of songs are being read out of USB audio devices.
• Connection stability and functionality with iPhone.
  • Device name can be displayed not only via BT connection but also via USB connection.
  • Improved stability when iPhone is connected via both BT and USB.
From 59.00.441 fixes these software errors (bugs):
• With ignition ON, “SCBS Unavailable” or “LDWS Unavailable” message may be displayed due to false error detection by CMU, but the systems actually do work. No DTC is stored in memory and no message appears in the multi-information display. (2014-2015 Mazda3 equipped with SCBS, LDWS and CMU version 59.00.441/443/445)
From 59.00.330 fixes these software errors (bugs):
• DTC U0100:00 [CONNECTIVITY MASTER UNIT] (communication error with PCM) is stored.
• Warning guidances displayed both for LDWS and HBC (CX-3 with LDWS / without HBC only).
• Improper OFF selection in the Setting Interval menu under Oil Change (CX-9 only).
• Resetting with “Fixed” data will not reset “Flexible” data. (CX-9 only).
From 55.00.760 fixes these software errors (bugs):
• Navigation or other screens freeze or reboot.
• Issues with Pandora Radio.
• USB device fails to start playing, resume or display music information. BT audio device fails when starting to play,
resume or connect.
• Paired BT device will not connect. Removing the paired BT device from the vehicle (but not the vehicle from the
phone) results in an endless “Deleting” message.
(From previous)
• Some street names in Canada are not displayed.
• Navigation does not allow to set certain cities as destination.
• Navigation does not announce voice guidance for street names.
• Navigation turns to a black screen, but the menu bar remains.
• Turn -by-turn navigation guidance does not display on the active driving display (for vehicles with 55.00.750).
• Every time the navigation is turned on, the vehicle position starts from the location (dealer) where the CMU was
updated from version 55.00.650 to 55.00.750.
• Navigation or other screen turn black, freeze or reboot.
• System does not recognize USB/SD card.
• Some menu of music source selection is grayed out.
• When using the call button on the cell phone to make a call, the call sound is short.
• Favorites disappear.
• Vehicle current position is not accurate enough.
• Rear view monitor does not show up on screen.
• Text information of HD radio is not displayed when switching music source.
• When asking for current location with voice command “Where am I?”, the system responds with “Your location is comma.”
• Contact information cannot be loaded correctly from phones other than iPhone.
Can you share me a firmware update to v70 for japannese version?
Hi @ASH8,
Kiwi here trying to understand if it is possible to update the firmware in my JDM Mazda Demio 2018 import with a AUS/NZ version?
What do I gain or miss out on if this is possible, I would like to attempt the update myself. As soon as I am authenticated I can DM you with my firmware version pic.
Thanks in advance!
Discussion starter · #378 ·
You people can't DM, PM me because you join a forum and want want want straight away in 5 minutes!.
This system does not permit private message UNTIL...
YOU Introduce yourself in New Member Thread.
Maybe comment in a few threads of interest, then come back 24 hours later and do this in a PM, DM to me by clicking on my Avatar...start conversation or message.
DO NOT POST requested Below IN THIS THREAD ASKING AS I WILL NOT RESPOND, only in a DM, PM.
Ă·Ă·Ă·Ă·Ă·Ă·Ă·Ă·Ă·Ă·Ă·Ă·
To Update MAZDA MZD CONNECT for CarPlayTM-AndroidAuto I Need to know what FULL Version Numbers are currently used in your car today :
1. Go to touchscreen red 'SETTINGS',
2. Side Scroll to Top Far Right Folder 'SYSTEM',
Scroll Down to 'ABOUT'
3. Touch 'Version Information'.
FULL Version Numbers and or Region Letters are revealed.
I Need to know....
1. The FULL 'Fail-Safe' Numbers.
2. The FULL 'OS' Numbers.
This VERIFIES These Are NOT MISS-MATCHED (This is a Very important Version check as you CAN NOT UPDATE FIRMWARE if there is a Miss-Match which happens when a person failed in a prior Firmware install).
Next ONLY send me a Picture of this your cars Version Information SCREEN here in our Private Message information for Both Files, the 'Failsafe' Version Numbers and 'OS' Version Numbers.
I Now ONLY issue out the Correct NEXT Genuine Firmware OS VERSION for Your Mazda to be Next Installed when you supply above in a Picture reply.
Also tell me (confirm) in what country is your Mazda NOW driven in as some in this Forum use VPNs that hides your real user country or has imported car from another Country. :)
2014-2018 Mazda3
2016-2023 Mazda2
2016-2021 Mazda6
2016-2023 CX-3
2016-2023 CX-5
2016-2023 CX-9
2016-2023 MX-5
  • Faster start up.
resume or connect.
(From previous)
Can you send the link to download for mazda 2 eu please
