441 - 447 of 447 Posts
WARNING: DO NOT USE ANY SMART PHONE TO DOWNLOAD FIRMWARE AND INSTALL OF FIRMWARE ONTO small USB FLASH DRIVE. ....ONLY USE A WINDOWS 11 PC - LAPTOP.
ALERT:
Please be aware that MAZDA ONLY Supports the WIRED Connected AUX Hub and Two Large USB Cables for Optional Carplay and or AndroidAuto Conversions.
GENUINE Mazda CP/AA Wireless is ONLY obtained by using an updated for ''Wireless CMU'' (the inside Dash Hardware) and the updated new AUX Hub.
MAZDA DOES NOT SELL or SUPPORT CP/AA WIRELESS VIA a ''Carplay Dongle'' only via more expensive "Wireless CMU".
These ''Carplay Dongles'' are not from Mazda nor can be considered a Genuine Mazda Part.
They are sold via Amazon, eBay etc, I would be careful about their longevity (or life span).
Personally I Only recommend the ORIGINAL CP/AA Update which requires the 2 Wired USB Cables and Updated AUX Hub or Box installation AFTER your 74.00.324A Firmware is working. The Latest and final 74.00.324A Mazda Firmware does work fine with these wireless Carplay Dongles, HOWEVER I recommend you ONLY use the Instruction I supply with all my Genuine Mazda Firmware as these other paperwork suppled is either old and outdated Firmware from a Google Link and instructions which is very vague.
NOTE: THERE ARE SOME PEOPLE CHARGING YOU FOR THESE UPDATES IN RUSSIA or UKRAINE, or on eBay or Amazon, I NEVER CHARGE YOU, YOU DO NOT PAY FOR NEW FILES, EVER
ALSO NOTE: YOU CAN NOT CHANGE or SWAP INFOTAINMENT SYSTEMS.
ALL EXPORT Mazda 2 USE the 6th GENERATION MAZDA CONNECT.
7th Gen MAZDA HOME SCREEN has the White Text on Black Screen.
6th Gen MAZDA HOME SCREEN has the Red Select Icons on Black Screen.
PLEASE NOTE: 74.00.324A IS NOW THE FINAL FIRMWARE as all Mazda Cars using this .up Firmware is OUT OF PRODUCTION and No Longer Installed in any New Mazda's made in 2024.
Yes, this Firmware update is for all Mazda 2s with the following Touchscreen as shown above then Yes you can also have the working and 100 % Genuine Mazda Carplay and or Android Auto if you desire.
The Genuine Mazda Firmware part of this I supply to you is all free you just message me (see below) the Country and Region you need with your current in car current Version number in use today, I will return you with the correct download link.
To find out what Version is in your Mazda 2 now do the following..
1. Touch Red Round Cog of "SETTINGS" on homescreen.
2. Next top of the screen far right grey Folder of "System".
3. Scroll down screen to "About", touch About.
4. Then touch "Version Information" this will show you current Firmware in use in your car today and the country or region code like EU N, or NA N or 4A N so please also must tell me what this is listed in your return message to me.
Once you have installed latest firmware and used in car, you then must Buy and Install the two sets of Genuine Mazda Parts which is the all new Aux Hub box and all new Cable Set of two cables that fits between existing CMU in dash (behind touchscreen) and new Aux Hub (where SD Card slots in).
New CP/AA Kit in Pic below.
You do not have to install new parts if you do not want a working CP/AA. You can just ONLY update to the new and latest Firmware 74.00.324, which gives you the latest updates and a faster to load and use MZD Mazda Connect System.
Please Note: I DO NOT supply or help with any AIO TWEAKS at all, you will need to start a new thread , please do not ask me about AIO Tweaks here, I will not reply.
WARNING âš  : DO NOT USE ANY USB FLASH DRIVE LARGER THAN 16GB IN SIZE.
ALSO NOTE: Do not rely on your Mazda Dealer to update your Firmware for Connect as most never will unless you complain of a specific issue or fault.
NOTE: Links to secure new Genuine Connect Firmware WILL NOT ever be posted publicly IN THIS THREAD or Forum, they will ONLY be supplied via a Private Message to you direct.
IF you are after the Genuine Mazda Firmware as listed PRIVATE MESSAGE me ONLY Here in this Forum with your Model, What OS Version Numbers are in each (Fail-safe and Reinstall) and what Country is car used in, SEND ME a Picture ONLY of the Screen "OS VERSION" Settings. New Members must post in Forum to Qualify.
CLiCK HERE Below...
Click to Message
PLEASE DO NOT ASK for FIRMWARE FILES in MULTIPLE MAZDA FORUMS.?
IF YOU ARE Messaging "ASH8" which is ME, then I Am THE SAME PERSON !
You won't get what you want any faster, but just create more work for me
FOLLOW ME
If you want to get instant notifications when I post New Content say on Bulletins or Firmware Updates just Click on my ASH8 Avatar, see the pop-up then Click on the '+ FOLLOW' Tab on Bottom Left of pop-up, it is that easy.
EXAMPLE BELOW OF THE SCREEN PICTURE I NEED OF YOUR FIRMWARE VERSION IN YOUR CAR NOW,
Then MESSAGE ME WITH YOUR PICTURE INCLUDED......
WARNING: PLEASE NOTE, IF YOU CAN NOT SUPPLY ME A PICTURE OF CARS EXISTING FIRMWARE VERSION IN Your PRIVATE MESSAGE TO ME TO VERIFY I CAN NOT ISSUE YOU THE MAZDA CONNECT UPDATE FILE(S).
THE .Pdf File for Firmware INSTALLATION INSTRUCTIONS ARE SUPPLIED inside EACH FILE SET.
THE .PDF INSTALLATION INSTRUCTIONS FOR New AUX Hub HARDWARE INSTALLATION IS IN THIS LINK HERE....AUX HUB AND CABLE HARDWARE INSTALL .PDFs
NOTE: MY REPLY to YOU can take up to 15 Hours as I am in Au or Australia please be patient.
Do Not download Firmware Files from any other Websites or YouTube as they offer zero support and usually
only one of the three Regions. You might BRICK your CMU.
I am using 2015 Mazda 2 and I have v70 available now but I want to make v74 please share the latest version with me
Hello ALL!
New firmware is out now for 4A N or ADR in 74.00.324A
This is the FIRMWARE ONLY that is the Operating System for your Mazda Connect or MZD Connect which uses the .up Firmware ONLY.
IF you are after any copies YOU MUST Message me privately for the link to Download the file, ALL install instructions etc are included in link.
I supply ONLY the Genuine Mazda Files, I do not hack, I do not recommend ANY Tweaks as they are more hassle than what they are worth.
ONLY the GENUINE Files I supply, exact same as your Mazda Dealer would use, nothing else.
This means ALL regions worldwide which use the .up Firmware use 74.00.324A as the latest and most updated Firmware.
74.00.324A NA N for North America, USA, Canada, Mexico, etc.
74.00.324A EU N for Europe and UK, etc.
74.00.324A 4A N (ADR) for Australia, NZ, Middle East, Thailand, South Africa, Oceania, etc.
May I request copy for a copy firmware update download for Mazda 2 2017 acquired model 2018. Im from the Philippines. Thank You
