181 - 200 of 447 Posts
Hello ASH8,
I have a Mazda 2 (2019) .
My actual firmware is :
59.00.545.EU N (OS)
00.08.000 Musique DB
59.00.545 Security version
I'm leaving in France (EU)
Is it possible to provide me the like for the 3 update ?
Many thanks for your help ;)
I really recommend this update, the display resolution seems higher than before. Maybe it is only a better anti-aliasing, but the images looks more detailed now, you can immediately verify it when the Mazda logo appears.
Hello ASH8,
I didn't received any news about my request, there is an issue or I did something bad ? ... I don't undersoud someting ? :)
In any case I try again with the request ;)
It's for a Mazda 2 (2019) .
Actual firmware :
59.00.545.EU N (OS)
French car (EU)
Is it possible to provide me the update ?
Let me konw and many thanks again for your help ;)
Hi ASH8,
I have a 2017 Mazda 2 here in Australia and would appreciate if you could send me the download link and tutorial.
I will be using this with apple Car-play after firmware update.
OS Version is 59.00.502 4A N
Music Database Version is 00.07.000
Fail Safe Version is 59.00.502
Thanks in advance
Message me for any links only, you must make a few separate posts in this forum first, make it simple like asking a question or agreeing with someone's comment an a thread.
Generally you need 2 to 3 posts and then wait for 24hours, then create Message by clicking on the person's Avatar, click on Message or Start Conversation.
Hello, I have a mazda 2 skyactiv 2018 in which i would like to make compatible with carplay/AAuto, i have version 59.00.XXX, I am trying to update to 70.00.100 4A N version but I couldn’t find this version anywhere. Thanks a lot in advance
NOTE: THERE ARE SOME PEOPLE CHARGING YOU FOR THESE UPDATES IN RUSSIA or UKRAINE, or on eBay or Amazon, I NEVER CHARGE YOU, YOU DO NOT PAY FOR NEW FILES, EVER!
Yes, this Firmware update is for all Mazda 2s with the following Touchscreen as shown above then Yes you can also have the working and 100 % Genuine Mazda Carplay and or Android Auto if you desire.
The Genuine Mazda Firmware part of this I supply to you is all free you just message me the Country and Region you need with your current in car current Version number in use today, I will return you with the correct download link.
To find out what Version is in your Mazda 2 now do the following..
1. Touch Red Round Cog of "SETTINGS" on homescreen.
2. Next top of the screen far right grey Folder of "System".
3. Scroll down screen to "About", touch About.
4. Then touch "Version Information" this will show you current Firmware in use in your car today and the country or region code like EU N, or NA N or 4A N so please also must tell me what this is listed in your return message to me.
Once you have installed latest firmware and used in car, you then must Buy and Install the two sets of Genuine Mazda Parts which is the all new Aux Hub box and all new Cable Set of two cables that fits between existing CMU in dash (behind touchscreen) and new Aux Hub (where SD Card slots in).
You do not have to install new parts if you do not want a working CP/AA. You can just ONLY update to the new and latest Firmware 74.00.324, which gives you the latest updates and a faster to load and use MZD Mazda Connect System.
Please Note: I DO NOT supply or help with any AIO TWEAKS at all, you will need to start a new thread , please do not ask me about AIO Tweaks here, I will not reply.
WARNING âš  : DO NOT USE ANY USB FLASH DRIVE LARGER THAN 16GB IN SIZE.
ALSO NOTE: Do not rely on your Mazda Dealer to update your Firmware for Connect as most never will unless you complain of a specific issue or fault.
NOTE: Links to secure new Genuine Connect Firmware WILL NOT ever be posted publicly IN THIS THREAD, they will ONLY be supplied via a Private Message to you.
Tips, Firmware Install instructions in.Pdf are also included with your particular download link.
Even a short how to install firmware video can be supplied if you wish.
74.00.324A EU N updated Nov 10th 2022, the fixes over 74.00.311A are ...
SYMPTOMS
The following symptoms can be improved by the latest software (Ver. 74.00.324A).
Improved symptoms depend on current software versions.
• If the shift lever is operated quickly while displaying CarPlayTM screen, the rear view screen may not return to CarPlayTM screen.
• When the gear position is shifted into P from R, the screen may not return to the previous condition before shifting into R position.
Hi ASH8, Thanks for the post!
i would love to have android auto on my mazda, the current OS version is:
56.00.513
EU N
Discussion starter · #196 ·
YOU MUST MESSAGE ME FOR Firmware INFO AND LINKS.
Click on my Avatar, then see MESSAGE in bottom right
Hand Corner, Click on "Message" to send me a message.
Tell me what FULL VERSION details is running in your car now.
If you are a new Member you must wait 24 hours AFTER YOU first Register as a member here to Message me.
