201 - 220 of 447 Posts
Tips, Firmware Install instructions in.Pdf are also included with your particular download link.
Even a short how to install firmware video can be supplied if you wish.
74.00.324A EU N updated Nov 10th 2022, the fixes over 74.00.311A are ...
SYMPTOMS
The following symptoms can be improved by the latest software (Ver. 74.00.324A).
Improved symptoms depend on current software versions.
• If the shift lever is operated quickly while displaying CarPlayTM screen, the rear view screen may not return to CarPlayTM screen.
• When the gear position is shifted into P from R, the screen may not return to the previous condition before shifting into R position.
Can you please share me the link to download as well?
Thanks in advanced.
NOTE: THERE ARE SOME PEOPLE CHARGING YOU FOR THESE UPDATES IN RUSSIA or UKRAINE, or on eBay or Amazon, I NEVER CHARGE YOU, YOU DO NOT PAY FOR NEW FILES, EVER!
Yes, this Firmware update is for all Mazda 2s with the following Touchscreen as shown above then Yes you can also have the working and 100 % Genuine Mazda Carplay and or Android Auto if you desire.
The Genuine Mazda Firmware part of this I supply to you is all free you just message me the Country and Region you need with your current in car current Version number in use today, I will return you with the correct download link.
To find out what Version is in your Mazda 2 now do the following..
1. Touch Red Round Cog of "SETTINGS" on homescreen.
2. Next top of the screen far right grey Folder of "System".
3. Scroll down screen to "About", touch About.
4. Then touch "Version Information" this will show you current Firmware in use in your car today and the country or region code like EU N, or NA N or 4A N so please also must tell me what this is listed in your return message to me.
Once you have installed latest firmware and used in car, you then must Buy and Install the two sets of Genuine Mazda Parts which is the all new Aux Hub box and all new Cable Set of two cables that fits between existing CMU in dash (behind touchscreen) and new Aux Hub (where SD Card slots in).
You do not have to install new parts if you do not want a working CP/AA. You can just ONLY update to the new and latest Firmware 74.00.324, which gives you the latest updates and a faster to load and use MZD Mazda Connect System.
Please Note: I DO NOT supply or help with any AIO TWEAKS at all, you will need to start a new thread , please do not ask me about AIO Tweaks here, I will not reply.
WARNING ⚠ : DO NOT USE ANY USB FLASH DRIVE LARGER THAN 16GB IN SIZE.
ALSO NOTE: Do not rely on your Mazda Dealer to update your Firmware for Connect as most never will unless you complain of a specific issue or fault.
NOTE: Links to secure new Genuine Connect Firmware WILL NOT ever be posted publicly IN THIS THREAD, they will ONLY be supplied via a Private Message to you.
Hi, i need the australian NEW 74.00.324A 4A or newer, thanks so much for your help
k
¡Hola a todos!
Ya está disponible el nuevo firmware para 4A N o ADR en 74.00.324A
Este es ÚNICAMENTE el FIRMWARE que es el sistema operativo para su Mazda Connect o MZD Connect que utiliza ÚNICAMENTE el firmware .up.
SI busca copias, DEBE enviarme un mensaje privado para obtener el enlace para descargar el archivo, TODAS las instrucciones de instalación, etc., están incluidas en el enlace.
Proporciono SÓLO los archivos Mazda originales, no los hackeo, no recomiendo NINGÚN ajuste ya que son más complicados de lo que valen.
SÓLO los archivos GENUINOS que proporciono, exactamente los mismos que usaría su concesionario Mazda, nada más.
Esto significa que TODAS las regiones del mundo que utilizan el firmware .up utilizan 74.00.324A como el firmware más reciente y actualizado.
74.00.324A NA N para Norteamérica, EE.UU., Canadá, México, etc.
74.00.324A EU N para Europa y Reino Unido, etc.
74.00.324A 4A N (ADR) para Australia, Nueva Zelanda, Medio Oriente, Tailandia, Sudáfrica, Oceanía, etc.
[/CITA] Estimado ASH8. Soy nuevo en el foro. Seria tan amable de compartir el Link para descargar la version 74.00.324 para sudamerica ( Chile) porfavor. Muchas gracias. Saludos
No unfortunately nobody has any JP M Firmware.
Can only install 74.00.311A for NA, EU or 4A N Firmware, but some existing JP M features will not work.
Hi Ash Could you please help me to upgrade my MZDA connect to latest firmware, currently i am running 59.00.502 4A N. i Appreciate any help that you can provide
Thank you and God bless.
Hey man, I cant message you, it says that I dont have all the requirmets to do it. can you dm me with the update firmware for my mazda 2. I have the 59.00.545 4A N. Thanks!!!
Hi, I am using Mazda 3, Residing in Dubai. I had recently the updated the infotainment system to 74.00.311 NA version, Now the issue is in the radio, I am not able to set the radio frequency. I read that North america has odd fraction (0.1, 0.3) radio signals, But in UAE there is odd and evn fraction as well. I would like to go back to the original system update or downgrade the system which can support UAE region. Anybody who can help me with this? Thank you in Advance.
Im not able to send a direct message but is there a way I can get the
Mazda Connect Firmware 74.00.324 update
